2000 Ford Focus
2000 FORD FOCUS
142,000 MILES • 4 CYL • 2WD • MANUAL
TUUTSIE34
had clutch replaced will not go into gear pumped clutch and did go into gear but stopped shifting again what would cause that
Apr 1, 2009 at 12:06 AM
RICH CRITES
  • 75 POSTS
Sounds like you need to bleed the hydraulic clutch. Jack your car up and put jack stands under it. Then bleed it like you bleed hydraulic brake system. Have one person in the car, press the clutch pedal down slowly three times, then hold it down. Have another person under the car with a length of hose leading into a plastic bottle with about a inch of fluid in the bottom of the bottle, make sure the end of the hose is in the inch of fluid in the bottle, so you can see if there is any air bubbles coming out of the hose and into the bottle. Repeat process until there is no more air bubbles. Hope this helps you
Apr 2, 2009 at 5:46 AM
