1995 Ford Fiesta
1995 FORD FIESTA
STEPH01
1995 Ford Fiesta
can you tell me why my car looses power i've got to keep my foot on the gas pedal to keep it ticking over if i dont it dies on me.
also when i put it from 1st to 2nd it makes a clunk noise and jirks like it jumps in to gear
thanks
May 29, 2010 at 8:21 AM
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
May 29, 2010 at 3:06 PM
