Hello
Thanks for the donation.
The first two places to start diagnosing is the spark plugs and the fuel rail. Pull spark plugs one at a time to check for bright blue spark jumping from plug to wires while assistant bumps engine. If all plugs have good spark, check fuel pressure at fuel rail with fuel pressure gauge. This will better pinpoint wether it is a spark issue or a fuel issue. Post the results and I will follow up.
Hope this helps.
Thanks for using 2carpros. Com!
SPONSORED LINKS
Thursday, January 1st, 2009 AT 1:20 AM
