Computer problem
2004 Ford Falcon V8 Two Wheel Drive Automatic
Hi, I Have a BA GT 2004 ford falcon the engine is a 5.4 Litre 290kw. The PCM module stuffed up in my car and ford replaced it with a second hand reco one, but i was told that they use a PCM module out of a Ba Xr8 ford falcon which has only 260kw. will this make a difference in the power output and also since in was put in went i start it runs rough and seems like its breaking down, when it warms up it seems to get better but every now and then it starts running rough again. Thanking u Jeff.
Dec 20, 2008 at 12:47 AM
