2000 Ford Falcon Headlights
BIGSTRUBER
Electrical problem
2000 Ford Falcon
I have looked at the manual and was just wondering if you had any advice on how to change the headlights on a ford falcon au series 2.
Oct 25, 2010 at 12:47 AM
  • 31,937 POSTS
Drivers side is hard to access due to the battery, rotate the large plastic cap and remove, unplug light, this can be a bit hard as some have a tag to push in on the side of the plug, normally they should pull straight off, remove rubber dust cap, globe is held in with a wire clip, you have to locate the lock end and release the clip, globe will come out.
mark (mhpautos)
Oct 28, 2010 at 9:14 AM
