1963 Ford Falcon Turning over an engine without the spark p
THEOSING
  • 1963 FORD FALCON
  • 6 CYL
  • 58,000 MILES
I am starting a restoration project on a car that has been stored about 10 years. Where should I begin? The engine is turning over but it won't start. Am replacing the points. What else should I do? This is my first restoration project. Also, should I take off all the trim, door panels, etc. Before having the car painted?
Sunday, September 19th, 2010 AT 6:39 PM
  • 31,937 POSTS
You will need to get the carby cleaned, it will be full of corrosion, replace the fuel filter clean the tank and ensure that the fuel pump is working, ensure you have a good spark at the coil when the points are fitted and re check the timing, all trim and glass should be removed before any painting is started.
Mark (mhpautos)
Monday, September 20th, 2010 AT 6:12 AM
