2000 Ford F-350 Power Steering Whine
SCFORD
I just picked my '2000 F350 up from the mechanic where I had the tires rotated and new front brake rotors and pads installed. Immediately upon moving the truck out of the parking spot, I heard a whinning sound that seemed to change in loudness as I turned the wheel. I drove around the parking lot then straight back to the mechanic to ask what they had done to the car. They came out, located the sound as emanating from the power steering pump. They topped off the fluid. The manager then told me it was a "common problem in Fords" for air to make its way into the system when they replaced the rotors and that the air would 'work itself out' as I drove around. I am concerned that they may have damaged the power steering rack when they put the truck on the lift, or that they somehow damaged the pump in the few hours they had the truck.
Any advice? Is there a way to get the air out of the power steering system if in fact this is the problem?
Thanks in advance.
Feb 14, 2006 at 6:21 AM
LOVESCARS
  • 359 POSTS
front brake rotor replacement has nothing to do with the power steering pump. ford p/s/pumps are noisey as a general rule but a whining noise????
maybe the belt, coincidental that the pump would go at the same time???
get another opinion
Feb 14, 2006 at 10:10 AM
Suggested Repair
Front brake rotor and pad replacement does not affect the power steering pump. Have another shop inspect the drive belt and power steering pump; the whine may be a normally noisy Ford pump, a belt problem, or a coincidental pump issue.
Conversation Summary
The owner of a 2000 Ford F-350 heard a whine that changed with steering right after a tire rotation and front brake rotor and pad replacement. The shop blamed air in the power steering system and said it would work itself out. The expert said rotor replacement is unrelated to the pump, noted that Ford pumps can be noisy, and suggested the belt or a coincidental pump problem, with a second opinion recommended.
