I noticed the brake lights ( both rears and upper cab lights) on when I shut the truck off after a short trip ( 4 miles) towing an 8,000lb trailer. The power light on my brake controller was also on. I disconnected the brake controller, no change. I removed the fuse for the brake lights, and they remained on. Everything works fine, including the brakes. I made sure the parking brake wasn't on. The only way to get the lights to go off is to disconnect the battery. Last brake job was about 30,000 miles ago. No problems since then
Oct 31, 2009 at 5:46 AM
