2000 Ford F350 Check engine light
F350MUDDER
  • 2000 FORD F-350
Computer problem
2000 Ford F350 Four Wheel Drive Automatic 98,965 miles
I asked a question before about my truck and the info was very helpful. I was getting the codes P1071 and P1074(system to lean) I noticed a big hole in my air intake hose, I replaced that, changed my fuel filter and cleaned the mass air flow sensor reset the check engine light drove my truck about 50 miles and it has'nt came on. Should it have came on if the problem was still present? Thanks in advance.
Thursday, August 26th, 2010 AT 3:29 PM
SATURNTECH9
  • 30,869 POSTS
A big hole in the intake will cause those code's you will just have to wait and see if the code come's back. There is no set mileage for a code to come back sound's like you fixed it though.
Thursday, August 26th, 2010 AT 6:38 PM
F350MUDDER
Just got back from the smog shop and my truck did pass after changing the fuel filter, air intake hose and cleaning the MAF sensor, thank you to all that helped me out.
Thursday, August 26th, 2010 AT 7:07 PM
SATURNTECH9
  • 30,869 POSTS
Glad to here you passed your smog check that's what here for.
Thursday, August 26th, 2010 AT 7:51 PM
