1999 Ford F350
1999 FORD F-350
200,000 MILES • V8 • 2WD • AUTOMATIC
MROYALS
I'm replacing the condensor,evaporator and accumulator, I know I need to measure the refrigerant oil from these componets and add equal amounts back to the system. If I remember correctly I need to add the oil back to the accumulator. Or should I add equal amounts back to each componet?
May 17, 2008 at 3:19 AM
MERLIN2021
  • 17,250 POSTS
Accum= drain and measure, add two ounces more.
Cnd= same amount.
Evap= Should come with right amount, lube o rings with new oil. use a new orifice tube in new evap...evacuate, charge and check...
May 17, 2008 at 3:35 AM
