1997 Ford F350 Vehicle Ignition
148,000 MILES • V8 • 4WD • AUTOMATIC
FORDMAN33
I have a 1997 F-350 with the E40D transmission and just got done changing the tranny filter. After topping off the fluid I went to start the vehicle to run through the gears before rechecking the fluid but now the truck won't start. Why?
May 9, 2008 at 1:30 PM
MASTERTECHTIM
  • 4,750 POSTS
give me a hint, whats it doing? cranking but not starting or not cranking over?
May 9, 2008 at 1:34 PM
FORDMAN33
it acts like the batteries dead but i put a tester on both and the both are putting out 12.6 volts. the weird thing is that all the lights are still bright until just after the glow plugs cycle, then they dim just a bit but the multimeter still reads good power.
May 9, 2008 at 1:39 PM
MASTERTECHTIM
  • 4,750 POSTS
do you get a click from the starter? check with a test light to see if you have power at the starter motor. ****make sure when you did the trans service that you did not accidentially knock off the wires on the transmission neutral safety switch. also try moving shifter into neutral to start or also try wiggling shifter and see if that has any affect
May 9, 2008 at 1:44 PM
FORDMAN33
I appreciate the help, tried it in neutral and part and wouldn't do anything but after the slight roll when i took my foot off the brake when going from neutral to park changed her mind and got her going. thanks again.
May 9, 2008 at 1:56 PM
