1994 Ford F350 engine will not turn over
BRENDARASH
  • 1994 FORD F-350
Engine Mechanical problem
1994 Ford F350 two Wheel Drive Automatic 70000 miles
I have a 94 ford E-350 [mini winnie] moter home that I started up with out any problems at all. I turned it off, after 15 minutes of running I turned it off. When I went to turn it back on 20 minutes later It would not even turn over at all The battery is new and was Charged and checked out fine. We tried to jump start it. Nothing You can here the sounds of something maybe fuel pump or something making a noise as usual but it[ the engine ]does not turn over at all. Could that be the starter? If you have any ideas I would appreciate it very much Thank you, Brenda
Friday, April 10th, 2009 AT 9:11 PM
Is it cranking over and refuses to start or just won't crank at all/nothing?
Saturday, April 11th, 2009 AT 3:31 AM
BRENDARASH
I started it the first time no problem, then once it was turned off I went to turn it on and nothing. No click no turn over but I could here the fuel pump hum as normal.I did move the moter home forward [that is what it is] a Minnie winnie.I have never had any problem with it not starting before. The problem is I parked it in the back of my house because it takes up my whole driveway. Now I cant get it out to get it fixed because its in the back lot. No tow truck can fit back there. Thanks for your help.
Saturday, April 11th, 2009 AT 7:03 PM
Load test the battey if okay make sure posts/cables are cleaned and tightened if okay -start checking the starter, starter relay, park and neutral switch and ignition switch.
Saturday, April 11th, 2009 AT 7:14 PM
BRENDARASH
We checked the battery it tested out to be okay, I did notice a small nest on top of the engine maybe a mouse I am not sure could that of chewed a wire if so why did it start fine in the beginning?We cleaned the battery posts ond charged it up its okay. The starter was hit and nothing a friend did something to try to jump start the starter at first it made a sound of a small motor but after one time it would not do it again. Thanks again Brenda
Saturday, April 11th, 2009 AT 7:38 PM
Check the rest of the items I've mentioned
Sunday, April 12th, 2009 AT 5:34 PM
