1987 Ford F350 f350 dump
1987 FORD F-350
SKULL12378
Electrical problem
1987 Ford F350 V8 Four Wheel Drive Manual
truckwill not get fuel. ive changed the fuel relay ,fuel pump, vapor valve ,brain on fender it is a 6/87 model with pumps in the tank and a carb . it ran good previously then it started to die after u use it and when u r dumping material it would start to die if u hit the pedal it would stay running then it would just die . it usually started back up but now it doesn't.
Nov 25, 2008 at 7:22 PM
