F250 Instrument panel
1925 FORD F-250
BSUTTN
1995 F250 w/120,00 miles = I need to replace the illumination lights in the instrument panel. How can I get to them?
Jan 5, 2007 at 9:59 PM
INDYUKE
  • 416 POSTS
You need to remove the trim that surrounds the instrument cluster, remove the screws that hold the instrument cluster in place, reach around behind the instrument cluster and disconnect the electrical connections, speedometer cable, etc., then you can pull it out and replace the lightbulbs
Jan 6, 2007 at 4:21 AM
