my ABS light comes on for approx 30/45 seconds after the engine is started
24,000 MILES • V8 • 2WD • AUTOMATIC
REQC7
I am 6 days out of warranty, and my ABS light comes on for approx 30/45 seconds after the engine is started. It then goes out and comes on about 20 t0 30 miles later. When it comes on after driving awhile, it stays on untill I stop and restart the engine. The engine is the 6.0 Diesel if that makes any differance. This truck is the Super Duty with the built in trailor brake control. I called Ford and they said "sorry you are 6 days out of warranty". Thanks for any help, John.
Nov 30, 2009 at 6:46 AM
DOCFIXIT
  • 18,828 POSTS
ABS has diagnostic capabilities have codes read then post and will advise as to repair. It sounds like you may have a wheel speed sensor that is out. These videos will help us find the problem.
https://youtu.be/rTtAnsOlZU4
and
https://youtu.be/Pb6nXV-iamI
and
https://youtu.be/ANWVTh2RQoQ
and
https://www.2carpros.com/articles/abs-warning-light-on-easy-repair-guide
Aug 4, 2019 at 4:40 AM
