2003 Ford F250 2003 Ford F250 Power Steering: Extremely ea
2003 FORD F-250
78,000 MILES • V8 • 4WD • AUTOMATIC
RNELSON
I have a Ford 2003 F250 5.4 L. The other day the power steering when turning left became very easy to turn the sterring wheel. Then a day later it became easy to turn both left and right. I can spin the steering wheel just about for lock to lock with one spin of the wheel while parked and the tires are still turing with the whell. I chekc the fluid it was about 3/4 of a quart low. I filled it up and can see the power steering fluid rushing through the resevoir.
Any ideas?
Thanks!
Jun 13, 2008 at 2:58 AM
MERLIN2021
  • 17,250 POSTS
You might want to get the steering box adjusted, Do this with only a qualified guy! Too tight and it can saw the sector shaft in two! Ford or a good alignment shop can handle it for you...
Jun 13, 2008 at 5:28 AM
