2002 Ford F-250 fuel
HARDING91
  • 2002 FORD F-250
  • V8
  • 4WD
  • 75,000 MILES
My son filled up my 7.3 diesel with gas.I know what to do, but I need to drain the tank.I have a pump but cannot get a hose into the tank.I assume there is a baffle. How can I bypass it. Tank is too heavy to drop down.
Thanks
Wednesday, December 31st, 2008 AT 3:46 PM
DAVE H
  • 13,384 POSTS
Remove fuel filter inlet pipe/hose from fuel filter find/buy a piece of hose to fit into fuel filter feed pipe from tank and use your pump to drain tank through filter inlet pipe/hose into containers. Some internal fuel tank pumps have a check valve inside. If your extra pump will not suck the fuel out you will have to drain by cycling the key switch on/off. May take all day but will drain the tank enough to let you drop it out
Excursion & F250-550 Pickup Middle Tank
Release fuel pressure. See FUEL SYSTEM PRESSURE RELEASE. Disconnect negative battery cable. Drain fuel from the fuel tank. Raise and support the vehicle. Disconnect fuel tank filler pipe hose and filler pipe vent tube. Remove skid plate, if equipped. Position jack under the fuel tank. Remove bolts. Partially lower the fuel tank. Disconnect fuel lines from fuel pump. Disconnect fuel tank connections and evaporative emission return tubes. Disconnect fuel tank pressure sensor harness connector. Disconnect fuel pump electrical harness connector. Lower the fuel tank. If a new fuel tank is being installed, transfer the fuel pump, fuel tank sending unit, evaporative emissions valves, and fuel tank pressure sensor (if equipped) to the new fuel tank. To install, reverse removal procedure. Tighten fasteners to specification. See TORQUE SPECIFICATIONS. Perform leak check and monitor procedure. See AFTER REPAIR PROCEDURE under EVAPORATIVE EMISSIONS SYSTEMS.
Excursion & F250-550 Pickup Aft Tank
Release fuel pressure. See FUEL SYSTEM PRESSURE RELEASE. Disconnect negative battery cable. Drain the fuel from the fuel tank. Raise and support the vehicle. Disconnect fuel tank filler pipe hose and filler pipe vent tube. Position jack under the fuel tank. Remove four fuel tank cover strap bolts. Partially lower the fuel tank. Disconnect fuel lines and electrical harness connector from fuel pump. Disconnect the hose(s) from the evaporative emission valve. Lower the fuel tank. If a new fuel tank is being installed, transfer the necessary components to the new fuel tank. To install, reverse removal procedure. Tighten fasteners to specification. See TORQUE SPECIFICATIONS. Perform leak check and monitor procedure. See AFTER REPAIR PROCEDURE under EVAPORATIVE EMISSIONS SYSTEMS.
Wednesday, December 31st, 2008 AT 5:12 PM
Related General Content
