1999 Ford F-250 truck stutters when applying light accelerat
MATTANDLULA
  • 1999 FORD F-250
  • V8
  • 4WD
  • 140,000 MILES
I have a 99 ford f-250 v10. When i'm maintaining speed w/ light acceleration on the pedal the truck will stutter and will go away if I gas it or let off the gas. I'm thinking it may be the MAF sensor going bad? You thoughts?
Tuesday, January 19th, 2010 AT 3:04 PM
1996F250
Try replacing your fuel filter, my 96 f250 was doing the same thing and that seemed to do the trick. After you remove the old one blow into it, if there is resistance when you blow then it needs to be replaced. While your at the store ask for a fuel filter removal kit, you will need it.
Saturday, January 23rd, 2010 AT 9:26 PM
