1999 Ford F-250 Engine Stop after 10 minutes running from co
RVILLALONGA
  • 1999 FORD F-250
  • V8
  • 4WD
  • MANUAL
  • 80,000 MILES
In the morning when I start the engine, run fine for about 3 miles, and engine shut off complete, after that it doesn't want to start, I replace, fuel Filter, and the problem still, I think that could be the Fuel Pump that doesn't have or after a few minutes loose fuel pressure, any help will be appreciated.
Monday, June 9th, 2008 AT 8:17 AM
RCKSTDY
Not a mechanic but we had the same issue sorta. The first thign to start with is the cam sensor. They are notorious for going bad. Some guy gave us one and it fixed our issue after figthing with it for few days. Just lucky but checkthat first the least expensive. Then check fp pressure and inertia sensor
Tuesday, June 16th, 2009 AT 5:32 PM
