1996 Ford F250 shane
1996 FORD F-250
BROUILLETTE420
Transmission problem
1996 Ford F250 V8 Four Wheel Drive 174000 miles
when i first start it up i have to push the gas pedal all the way down,starts right up and when i take off ait has a slight delayed shift and jumpy.auto trans.i
May 22, 2010 at 2:56 PM
OBXAUTOMEDIC
  • CAR REPAIR CONTRIBUTOR
  • 3,711 POSTS
Your problem could be either a weak fuel pump or bad fuel pressure regulator.
You shouldn't have to press pedal to floor to start a fuel injected vehicle. Try turning key to on position then back off a couple times then try starting without pressing pedal. If starts fine then most likely you have a bad pressure regulator.
May 24, 2010 at 10:27 AM
