That is the second back on drivers side. Unbolt fuel rail from intake manifold, clean around base of injectors so debris wont fall into the engine. Pop the injectors up out of the lower intake and put in new one. I would replace all o'rings while in there and a little WD-40 helps it all go back together easier
SPONSORED LINKS
Thursday, March 6th, 2008 AT 8:02 AM
