1992 Ford F-250 134A in an R12 system
OKIEPLAYER32
  • 1992 FORD F-250
Air Conditioning problem
1992 Ford F250
I took my pick-up to a mechanic to get air system recharged, the mechanic put 134a in my r12 system. I did not realize until a few days later when the air would no longer cool, I took it to another mechanic and he said because of nothing being converted and the r12 still in the system I was going to have to replace my whole system now, is this true and if so should the first mechanic be responsible for the damages?
Friday, August 21st, 2009 AT 6:24 PM
FRANKHALLMAN
Replacement. Yes. The R134a is more corrosive to a system than R12. It attracts water. It uses PAG oil vs mineral oil for R12. If you never had a conversion from R12 to R134a, you should have screw type access ports on the suction line and discharge line of the compressor. A retrofit kit would have quick diconnect ports that screw onto the original threaded ports. The mechanic that charged your system probably should have been aware of that since it is a major difference.
Saturday, August 18th, 2012 AT 3:08 AM
