1989 Ford F-250
MARKWHITE1020
  • 1989 FORD F-250
  • V8
  • MANUAL
  • 151 MILES
When engine is cold oil preasure is at 30 psi after engine warms drops to 2 psi I changed the oil pump with a high volume same probelem when I got into the project I noticed somebody has already pulled the pan before and both heads I justn bought the truck and the engine is real strong what should I do next im running on no budget and I need the truck for work thank u for your time
Tuesday, November 25th, 2008 AT 12:46 AM
Warm oil pressure at 2psi is not gonna make it-either the high volume pump is sticking open or it has serious engine bearing problems-could be the wrong undersize bearings. My thoughts the engine rebuilding process is not done properly
Tuesday, November 25th, 2008 AT 1:43 AM
