1979 Ford F-250 oil pressure
CONFUSEDFORD79
  • 1979 FORD F-250
  • V8
  • 200,000 MILES
I am working on a 1979 ford f-250 with a 400 ci. 6.6 liter v-8 and it has good oil pressurearound 50 psi until it warms up then as it warms up it slowly drops to 15-20 psi. My question is is it normal and safe to drive and if not what can I do to fix the problem
Tuesday, July 28th, 2009 AT 9:28 PM
  • 31,937 POSTS
Hi there, Hot idle oil pressure of around 20 psi is fine, what is it hot at around 2000 RPM? Are you checking the readings with a mechanical gauge?
Mark (mhpautos)
Tuesday, July 28th, 2009 AT 10:35 PM
CONFUSEDFORD79
I went and bought a mechanical gauge today and I am not sure wht the rpm is it does not have a tach unfortunately I know the rear main seal is going bad and I am in the process of changing that along with the front main seal, oil pump, and pan gasket but the problem is it is my only mode of transportation so I need to know if it will hurt it to drive short distances until I get these things fixed I do know that even when the pressure drops if I push on the gas the pressure rises with the rpm's that is all I can tell you sorry I can't be more specific
Tuesday, July 28th, 2009 AT 11:36 PM
  • 31,937 POSTS
Hi there, as long as the pressure rises with engine rpm you should be ok, but don't push it to hard.
Mark (mhpautos)
Tuesday, July 28th, 2009 AT 11:43 PM
Related General Content
