1976 Ford F-250 Won't shift from column
KCORRIGAN
  • 1976 FORD F-250
  • V8
  • 73,000 MILES
The shift linkage from the column to the transmission won't work. Can manually shift at transmission, do you have any suggestions or a diagram of the wiring, etc to check on the steering column?
Monday, July 20th, 2009 AT 3:20 PM
JDL
  • 16,098 POSTS
Just a thought, you might call around to some of the local boneyards, see if they might have a steering column that will work. Swap out the whole column. Sorry, I don't have any diagrams of the column.
Monday, July 20th, 2009 AT 3:50 PM
