1999 Ford F-150 Rough Idle Misfire
MIKE123
I have a 1999 ford f150 lariat , it just started to run rough out of the blue, like it had a bad mis in it, check engine light came on. when i have car in park you can barely feel it but when i put it in reverse or gear you can really feel it misfiring . rough idle at slow sppen but kind of gets better when the rpms get higher. could this be bad plugs or water in my gas? i used gumout jet cleaners beacuse it felt like maybe the injectors were getting dirty. please help lol
Dec 26, 2006 at 1:13 PM
BLACKOP555
  • 10,386 POSTS
since you have a check engine light you should always have it checked it should lead you right to the problem. a random missfire and a single missfire has complete diff solutions.
Dec 28, 2007 at 2:14 PM
Suggested Repair
Scan the check engine light codes before replacing parts. A random misfire and a single-cylinder misfire require different repairs, so do not assume plugs, water in the fuel, or dirty injectors until the codes are read.
Conversation Summary
The owner of a 1999 Ford F-150 reported a sudden rough idle and misfire that was barely noticeable in park but strong in gear, improving at higher RPM. The check engine light was on, and the owner wondered about plugs, water in the gas, or dirty injectors after using fuel cleaner. The expert advised scanning the check engine light first because random and single misfires have different solutions.
