The rise in temperature then dropping to mormal sounds like themastat is sticking. Check your belts
to make sure they are not loose, since you have heat at times it does not sound like its vapor locked.
Make sure fluid level is up.
SPONSORED LINKS
Tuesday, February 6th, 2007 AT 3:23 PM
