Overheating
COONASS2DABONE
  • FORD MUSTANG
I have a 1995 ford mustang GT 5.0 with 115000 miles, when I crank my car it will set there and idle for about 15- 20 minutes gradually the temp. Increases but does not get into the red zone, I can take it down the road and with the forced air the temp. Drops to normal, when stopped the temp. Agian rises, I have a new water pump, new fan motor, new 160 deg. Thermoistate I flushed the raidiater with store bought radiater flush.
Friday, January 26th, 2007 AT 12:15 PM
2CARPRO JACK
  • 11,533 POSTS
First of all you need to put the factory 195 t-stat back in it. When they arent running at proper temp the emissions and performance will lag. In the underhood fuse block there is a 60 amp fan fuse, check that first. Does the cooling fan turn on when the a/c is on? The cooling fan gets its trigger from the PCM, there is a Constant COntrol Relay Module behind the coolant resevoir, it has the relay in it for the cooling fan and could very likely be the problem
Friday, January 26th, 2007 AT 12:32 PM
COONASS2DABONE
[Ok I will replace the thermastat back to the origanal, It is not the fan fuse cause the fan kicks on when it is supose to and the A/C in the car dosnt work thats next, I think the comp. Is out in it
Friday, January 26th, 2007 AT 12:53 PM
2CARPRO JACK
  • 11,533 POSTS
When the cooling fan runs does it stay on? Or does it shut off after cooling the engine? Look for obstructions in front of the radiator
Monday, January 29th, 2007 AT 9:45 AM
COONASS2DABONE
1995 Ford Mustang 115000 5.0 The fan kicks off after the engine cools, I'll take a look at the radiator for obstructions.
Monday, January 29th, 2007 AT 10:44 AM
2CARPRO JACK
  • 11,533 POSTS
If the fan turns off in a reasonable amount of time, the gauge might be off. An infra-red heat gun will tell you if the gauge and actual temp are near each other
Monday, January 29th, 2007 AT 2:46 PM
