1988 Ford F-150 Front Lug Bolts
88FORDF150
I'm trying to change the lug bolts on an 88 Ford F-150 4X4. I'm not sure how to get the lug bolts off. My haynes manual doesn't tell me how to do this. I know how to do it to the rear wheels, but I don't know how to do it to the front wheels.
Jan 10, 2007 at 6:46 AM
SERVICE WRITER
  • 9,123 POSTS
Manual or locking hubs? Do you know how to get those off?
I believe they are part of the rotor. Once the rotor is off they get pounded from the face and out the back. Put the new one in the hole and draw it up with an old lug nut put on backwards. Remove and Discard the nut replace with new nut.
Jan 10, 2007 at 7:01 AM
88FORDF150
I removed the manuel hub lock, and i removed the hub lock ring, but then my haynes book tells me to remove the stop screw... I don't have a stop screw...
Jan 10, 2007 at 7:27 AM
SERVICE WRITER
  • 9,123 POSTS
If you removed the lock ring, the hub should slide out.
Jan 10, 2007 at 7:44 AM
88FORDF150
it is not sliding out, i guess i can just hope someone does it in the middle of the night for me.
Jan 10, 2007 at 12:13 PM
SERVICE WRITER
  • 9,123 POSTS
Service writers prefer to not get their hands dirty :lol:
Install new of the cap screws into the body of the hub so you have something to pull it out with.
Jan 10, 2007 at 12:32 PM
HEAVYDUTY
  • 60 POSTS
the set screw they refer to i bilieve is the keythat is in the slot that the lock ring was holding in. a small magnet is needed to coax it out then the nut will turn off
Jan 14, 2007 at 1:02 PM
Suggested Repair
After removing the manual hub lock and lock ring, use a small magnet to remove the key from the slot so the nut can turn off. If the hub will not slide out, thread cap screws into the hub body and pull it out. With the rotor off, drive the old lug bolts out from the face toward the back. Insert each new bolt and draw it into place with an old lug nut installed backward, then discard that nut and use a new one.
Conversation Summary
The owner of a 1988 Ford F-150 4x4 with manual hubs wanted to replace the front lug bolts but could not find the stop screw described in the Haynes manual after removing the hub lock and lock ring. Advice was that the hub should slide out once the lock ring is removed, and that cap screws can be installed in the hub body to pull it if it sticks. Another reply identified the referenced set screw as the key held by the lock ring and said a small magnet can remove it so the nut will turn. The lug bolts were described as part of the rotor and are driven out from the face, then new bolts are drawn in with a reversed old lug nut that is discarded.
