1997 Ford F-150 Warm Miss and Brake Loss Fix
98RANGERXLT
  • 301 POSTS
Hello i have a 1997 ford f-150 with 4.6 v8 and an automatic i am having some problems,when the engine is warm it misses really bad as low as 200 rpm and i lose the brake booster if anybody can help that would be great otherwise i am stuck at school i tied changing the fuel filter and the egr valve but couldnt
Oct 25, 2007 at 9:09 AM
  • 75,988 POSTS
Check engine light is it On?
When was the last tune-up? Charging system is it okay-if there's a problem with system voltage the parameters and actuators will no function correctly to include the computer.
Try the idle air control valve open it up and clean it, brake booster could be leaking or vacuum hose. MAF/ IAT/TPS sensors
Oct 25, 2007 at 9:31 AM
98RANGERXLT
  • 301 POSTS
Check engine light was on but i cleared the codes the last tune up was like 15 thousand miles ago the brake booster isnt leaking it just started doing it when the engine was missing bad
Oct 25, 2007 at 9:34 AM
  • 75,988 POSTS
What was the last code you seen and relates to what?
Scan it again maybe something else might pop up. And do your basic's.
Oct 25, 2007 at 2:04 PM
98RANGERXLT
  • 301 POSTS
I founbd it last night i knocked the brake booster vac line off the engine my dad put it on and now it runs fine
Oct 26, 2007 at 9:04 AM
  • 75,988 POSTS
I gave you the brake hose 2 days, what happened?
Oct 26, 2007 at 1:07 PM
Suggested Repair
Reconnect the brake booster vacuum line that had been knocked off the engine. Once it was reattached, the warm miss and loss of brake boost stopped and the truck ran fine.
Conversation Summary
A 1997 Ford F-150 4.6 V8 automatic missed badly when warm, dropping as low as 200 rpm, and lost brake boost. The fuel filter and EGR valve had already been addressed. An expert suggested checking the check-engine light, charging system, idle air control valve, sensors, and brake booster vacuum. The owner later found the brake booster vacuum line had been knocked off the engine; after it was reconnected, the truck ran fine.
