Ford F-150 2004 -5.4 ,58175 milage
2004 FORD F-150
SMITTYDOES
Hello ,I have the truck mentioned above .My question is what causes wheel nibble in the front end .The sterring wheel moving side to side at speeds above 110 .The steering rack has been changed .It has new tires which have been road forced balanced .The drive shaft has been rotated 180 degrees .I am at a loss ,any feedback would be appreciated ,thanks smittydoes
Nov 27, 2007 at 2:39 AM
MERLIN2021
  • 17,250 POSTS
If you mean what is causing tire scallpoing, change the shocks! And tires now, once scallpoed, always scalloped! Same applies to a jumpy front end!
Nov 27, 2007 at 4:56 AM
SMITTYDOES
[quote:92e6baaf19="merlin2021"]If you mean what is causing tire scallpoing, change the shocks! And tires now, once scallpoed, always scalloped! Same applies to a jumpy front end![/quote:92e6baaf19]
thats not I mean ,ford calls it a wheel nibble .the steering wheel shakes back and forth at high speeds
Dec 1, 2007 at 1:56 PM
MERLIN2021
  • 17,250 POSTS
Do you have a steering stabilizer? At 110 You must be the Police! Speeds this high require a stabilzer...
Dec 1, 2007 at 11:11 PM
