2000 Ford F-150 4WD Not Engaging
hey camp you cannot repair them , if you found that was your problem , go ahead and replace it , anything else let us know
jim
Suggested Repair
The vacuum axle lock cannot be repaired; replace it if it does not travel far enough to lock the hubs. Also inspect the vacuum tubes at the wheels for rust, clean them, and reseat them to stop vacuum loss. Experts recommend keeping the original system rather than converting to manual lockout hubs.
Conversation Summary
A 2000 Ford F-150 4x4 with a 5.4L does not engage four-wheel drive. The transfer-case shift motor was replaced and the case now shifts, but the hubs still do not lock. The vacuum axle lock moves into two-wheel drive but does not travel far enough for four-wheel drive. One reply suggested manual lockout hubs. Experts said the vacuum actuator cannot be repaired and should be replaced if it is the fault, and that rusted vacuum tubes at the wheels should be cleaned and reseated to prevent vacuum loss.
