1991 Ford F-150 Rich Miss
DRIZZT_MICHEAU
The truck is 91 ford F-150, 302, 4x4 manual. Bought the truck in rough shape... It idled and ran very badly, so replaced plugs, wires, cap, rotor, and fuel filter. Truck still wouldnt idle well, so replaced idle control module/ motor. when I push in clutch, engine will over rev, or drop rpms to near death levels still. Also, engine misses, fairly bad. In addition, chewing through fuel at alarming rate, about 6 mi per gal on rear, and far worse on front tank I think. No leak in line, good pressure at regulator. Confused as to what would cause the miss and poor fuel milage. Very obvious engine running VERY rich. Any suggestion?
Feb 26, 2007 at 6:59 PM
INDYUKE
  • 416 POSTS
Are you able to hook a code scanner up to it and see if the computer is setting any fault codes? If you don't pull anything up, I would then double check the basics first. Adequate fuel delivery, spark plugs firing at the right time. Check compression as well. (how many miles on the engine?)
Don't rely exclusively on the computer though. Being a '91, the computer won't pick up on what's about to fail, only what already has. So you could have a sensor or a solenoid way out of whack and the computer wouldn't know it. I hope this helps.
Feb 27, 2007 at 11:41 AM
DRIZZT_MICHEAU
The truck had 130000 mi on it. I dont know about the trouble codes, but check engine light comes on after a few minutes of starting it, and that is where it starts to drive poorly. It is getting fuel, good fuel pressure, fresh tuneup with good spark, just timed. I have checked through everything on fuel system, except injectors. Would injectors sticking open cause it to dump fuel badly, miss, yet still run well enough to get up to 65?
Feb 27, 2007 at 1:59 PM
INDYUKE
  • 416 POSTS
Yes, a stuck injector will cause those symptoms. It will also cause the truck to run with a noticable "thub, thub, thub" with a constant poof of white steam out the tailpipe.
Possibly in this case, being able to scan the computer for fault codes will give you the clue you need to narrow down the problem. Since it's starts to perform poorly when the check engine light comes on, (that indicates fault code(s) was set) that would be an emission component related problem.
Mar 2, 2007 at 12:08 PM
DRIZZT_MICHEAU
thanks for the replies. It was a fuel pressure reg.
Mar 6, 2007 at 9:44 PM
Suggested Repair
Replace the fuel pressure regulator. The owner confirmed that a faulty regulator caused the rich running, miss, unstable idle, and poor fuel economy. Also scan for codes and verify fuel pressure, spark timing, and compression.
Conversation Summary
A 1991 Ford F-150 with a 302 engine idled poorly, missed, surged or nearly stalled when the clutch was pressed, and used excessive fuel while running very rich. Plugs, wires, cap, rotor, fuel filter, and the idle control motor had already been replaced, and fuel pressure was good. The expert advised scanning for codes once the check engine light came on, then checking fuel delivery, spark timing, and compression, and noted a stuck injector or emissions fault could cause similar symptoms. The owner later reported the fuel pressure regulator was the cause.
