Yeah if your heater core is inside the cab, 1. No you do not have to discharge the ac since the heater core is in the coolant system, I do recommend draining the coolant and disconnecting the lines from the engine compartment and getting as much coolant out as possible from there before removing it, and 2. That's probably exactly the reason you're smelling antifreeze is the heater core.
SPONSORED LINKS
Tuesday, June 26th, 2007 AT 7:56 AM
