Hi there'
We don't want to jump the gun here as I only suggest this as a possibility drawing on previous experience, this may not be your primary problem, heavy towing with only having small factory coolers has been a concern in the past, I would suggest as a starting point get the trans serviced by a trans specialist and get as report, I do recommend having a larger oil cooler fitted as a precaution, as transmissions wear with age, you need this added protection against possible over heating issues, sorry if I did not make my self clear in the first post.
Mark (mhpautos)
Sunday, May 16th, 2010 AT 7:20 PM
