2004 Ford F150 Cracking noise
80,000 MILES • V8 • 2WD • AUTOMATIC
FRANKTHETANK
Well I just resently started hearing a cracking noise comeing from the bottom of my truck sometimes when I first start it up not all the time but as soon as I start it up you can hear the noise and then it go's away I think it might be the oil pump bcus when my mechanic did the last oil change and he started the engine the truck made the same noise but for a longer period of time..so just wondering if it is the oil pump or if it is something else.. Thanx for the help
Nov 16, 2009 at 11:42 PM
  • 110,248 POSTS
Does it happen when the truck is stopped or moving?
Nov 17, 2009 at 9:28 AM
FRANKTHETANK
no only on some start ups. when the truck is already kind of warm it wont do it or after the first start up i could turn it off and turn it back on and it will not do it ,,,, i guess is only at first when the oil is down thats why im guessing it is the oil pump
Nov 17, 2009 at 3:20 PM
