2003 Ford F150 DTC
2003 FORD F-150
173,125 MILES • V8 • 2WD • AUTOMATIC
FASTFORDS
DTC-P0172B, P0175B, P01507-Sugestions
Aug 30, 2009 at 5:03 AM
MJR346
  • 132 POSTS
not familiar with the p1507 other than I believe it's a IAC under speed error (Idle motor cannot control idle and idle speed was too low)
The p0172,p0175 means banks one and two are running rich for some reason causing the o2 sensors not to cross count.
Usually high fuel pressure, plugged cat convertors, leaking injectors and such will cause this
https://www.2carpros.com/trouble_codes/obd2
Aug 30, 2009 at 10:39 AM
