2. Current odometer reading 80000
3. Automatic Transmission
4. Strange sounds or smells (if any) none
5. Fluid leaks (if any) none
The truck starts normally but when you go to shift gears it will not shift. I tryed to shift it with the truck off and it still wont shift. I havent had a problem with the transmission ever and the fluid are up to part. I checked the fuses and they seem good. Do you know what the problem could be. And if so do you know how to check if that is the problem.
SPONSORED LINKS
Thursday, November 29th, 2007 AT 5:38 PM
