2002 Ford F150 Need Help Starting F150
2002 FORD F-150
138,000 MILES • 6 CYL • 2WD • AUTOMATIC
3903FOSTER
I replaced the fuel filter on my 2002 F150 and now it won't start. No fuel is leaking, and when I turn the key, the light indicating the fuel cap is off comes on.
The fuel cap isn't off.
Any ideas?
Mar 15, 2010 at 12:31 PM
CARADIODOC
  • 34,381 POSTS
The light is not for the fuel cap, . . specifically. It means the Engine Computer has detected a problem and set a diagnostic fault code in memory. That code will lead you to the circuit or system with the problem, not necessarily the defective part.
caradiodoc
Mar 15, 2010 at 1:22 PM
3903FOSTER
While changing the fuel filter, I had the hood popped to release the pressure via the Schrader valve on the engine. I noticed some corrosion on the battery terminals and poured a little classic coke on them to work it's magic while I was under the truck. Apparently the gunk built up on them was completing the connection it needed to run.( A lot of you are probably cringing at the neglect...) It won't happen again.
After about 2 hours of constant- baking soda and water scrubs with a toothbrush, I was able to get the connections off and clean them thoroughly. Now they look brand new and everything is running smoothly.
Better actually.
Mar 15, 2010 at 3:24 PM
CARADIODOC
  • 34,381 POSTS
Wonderful happy news! Stand closer to the 'puter so I can pat you on the back.
caradiodoc
Mar 15, 2010 at 4:20 PM
