engine stalls when put in gear
2001 FORD F-150
ABREITBACH
Transmission problem V8 Two Wheel Drive Automatic 88,000 miles
My truck idles fine but stalls or nearly stalls when I put it in gear. I can occasionally get it to avoid the stall if when I put it in reverse with my foot off the brake. It will shudder and then start going normally. I can also get it to go in either gear if I get on the accelerator as I put it into gear.
Once moving, it will surge and shudder as it nears a stop and if it doesn't stall it will seem to idle fine (in gear).
There is no CEL/MIL.
I replaced the DPFE valve because of a CEL last year.
I also removed the vacuum line from the EGR and applied vacuum directly to the EGR with the truck idling in park, which resulted in the engine stumbling.
If the truck is off and in gear I am able to roll it forward and back by hand, so the torque converter doesn't SEEM to be locked up.
Please help.
Thank you,
Aaron
Aug 25, 2009 at 6:40 PM
