With the ABS Light could be that there is debri between the sensor and ABS Ring. Suggest first try spraying off with water.
With the starting next time turn key to on position without trying to start, do this about 3 times and on the 4th time start the vehicle if vehicle starts normally then you have either a weak fuel pump or a bad fuel pressure regulator...
To test check out following link...
https://www.2carpros.com/dia/test_fuel_pressure.htm
Mark S
SPONSORED LINKS
Saturday, November 21st, 2009 AT 7:32 PM
