2000 Ford F150 Head lights, dash lights and tail lights
2000 FORD F-150
98,000 MILES • 6 CYL • 4WD • MANUAL
RICHARD KIMERY
Having problems with headlights remaining on and being unable to turn them off after the engine has been running. No tail lights and dash lights. All of these started at the same instant. Have checked the switch for headlights and removed it to turn off headlights but they remain on. Only way to turnoff headlights is by removing fuse under hood. If the engine is not started then can turn headlights on and off at the switch. The taillights do not work, but turnsignals and brake lights do work. What could be the problem ?
Mar 9, 2009 at 12:42 PM
