1998 Ford F150 oil and coolant gauge
1998 FORD F-150
270,000 MILES • V8 • 2WD • AUTOMATIC
PEPPER_12000
  • 5 POSTS
after running for about 5 minutes the oil and coolant gauge peg. Oil and coolant levels are fine. Any suggestions what needs to be done to fix problem?
Jan 24, 2009 at 10:05 PM
  • CERTIFIED EXPERT
  • 110,176 POSTS
Hi:
If the engine is not over heating or blowing the oil filter apart, there has to be a short in the wiring. The only thing I would recommend is to check the wiring for damage.
Jan 26, 2009 at 4:16 PM
