When I pulled the truck out of the garage the 4X4 and Low Range lights were on and the truck is in 4X4 low range. Turning the switch back and forth did nothing. I replaced the switch thinking it had mysteriously gone bad, evidently it didn't go bad. I checked all the fuses, none of them were bad. I checked all the plugs under the dash, they all are ok. Nothing is clicking in the transfer case or front end like it should and used to at all. It does nothing as if the switch isn't connected, it is of course. I've tried switching it under several different conditions, in park, neutral, drive, reverse, brake on, off motor running, shut off, key on and off. Nothing is happening at all. It's stuck in low range.
Oct 24, 2008 at 11:18 PM
