1997 Ford F150 leaking master cylinder
169,000 MILES • V8 • 4WD • AUTOMATIC
DEWAYNE
  • 7 POSTS
I replaced the master cylinder but it is leaking from the bottom. Is it possible that it is cracked. Is there a gasket between the power assist and the master cylinder?
Jun 4, 2009 at 12:44 PM
  • 75,988 POSTS
I thought I've answered this already If its leaking at the end of the MC where it meets up the brake pedal-The primary and secondary piston seals are leaking There's no gasket there
https://images.2carpros.com/forum/automotive_pictures/12900_brake_master_cylinder_1.jpg
Jun 4, 2009 at 1:00 PM
DEWAYNE
  • 7 POSTS
The seals are on the reservoir, correct? Do I need to replace the reservoir. Do I have to bleed the brakes if I remove the reservoir?
Jun 4, 2009 at 2:09 PM
  • 75,988 POSTS
Sir the master cylinder is leaking it doesn't matter where its leaking it needs replacing.
Jun 4, 2009 at 2:22 PM
DEWAYNE
  • 7 POSTS
Whoa, Whoa, Whoa, I just asked a legitimate questsion. The reservoir is not the master cylinder and I just replaced the master cylinder. So should I replace the master cylinder and the reservoir
Jun 5, 2009 at 3:07 AM
  • 75,988 POSTS
replaced the master cylinder but it is leaking from the bottom. This one gave me a curveball.
Sir-you might as well replace both-The brake system is the most deadliest system of all -don't gamble replace it.
Jun 5, 2009 at 8:33 AM
