1997 Ford F-150 Corrective action and required repairs to CL
LOSTINSPACE
  • 1997 FORD F-150
  • V8
  • 4WD
  • 17,000 MILES
Hello-getting PO 136, 401, 306 need to clear to get inspection-What will I need to buy to clear up-Thanks
Wednesday, July 30th, 2008 AT 5:05 PM
BMRFIXIT
  • 19,053 POSTS
The same tool u used to get the codes should help u clear them code
also disconnecting the battery will do so (clear the codes )
the issue is that u need a sticker and doing that will not work
u have to fix the truck
see u still can get rejected because the monitoring system in the truck was cleared and it will show that its not ready
and then u have to complete a drive cycle with out any codes to get the sticker
p0136 O2 sensor circuit
p0401 egr
p0306 misfire on cylinder # 6
my suggestions do a tune up or at least check cyl. #6
check EGR valve and it DP sensor and hoses
before the sticker
good luck
Thursday, July 31st, 2008 AT 6:08 AM
LOSTINSPACE
I guess you misunderstood the question-I need to know what you would do to correct the problems-I know how to clear them-that is not the issue-The OBD gives a general area to start-but I do not do this everyday and do not wish to buy a bunch of parts I do not need
Thursday, July 31st, 2008 AT 7:00 PM
BMRFIXIT
  • 19,053 POSTS
Sorry about that !
code 0401 :
most common with that code is the EGR sensor
I would check it hoses and connector
check EGR passages and clean as needed
90 % of the time we found replacing the sensor solved the problem .
https://www.2carpros.com/forum/automotive_pictures/99387_f150v8_1.jpg
code p0306
cylinder # 6 is a misfiring
start by checking the tune up
Possibility on p0136
damaged wiring harness or connector
exhaust system leak
defective O2 sensor bank1 sensor 2
Thursday, July 31st, 2008 AT 8:17 PM
Related General Content
