1997 Ford F150 ball joint?
1997 FORD F-150
TLSPANG43001
Noises problem
1997 Ford F150 6 cyl Two Wheel Drive Automatic
97 Ford F150. Front drivers side wheel area has squeak. Mechanic friend thinks ball joint needs lubed, but was also told that it is a sealed unit. Do I have to just live with it?
Is there another joint/connection that might be making the same noise?
Dec 12, 2008 at 7:15 PM
BMRFIXIT
  • CERTIFIED EXPERT
  • 19,053 POSTS
Has to be replaced
if dry and making noise need to be replaced
Dec 12, 2008 at 7:26 PM
TLSPANG43001
Any other piece that could be making the same noise?
Dec 12, 2008 at 7:35 PM
BMRFIXIT
  • CERTIFIED EXPERT
  • 19,053 POSTS
tie rod will too
Dec 12, 2008 at 8:31 PM
