Everyone has been stumped with this problem, I hope you can help. This is the 4.2L V6. Lower and upper intake gaskets have been replaced.
The truck idles rough or possibly misses at idle. Enough to feel the seemingly random miss in the steering wheel and seat. The engine also jerks due to the issue. No check engine light. Sometimes when started truck will shake and stall but restart fine.
I have done plugs (champion) and wires, idle air control valve, cleaned the egr ports and checked fuel injectors, replaced driver side upstream O2 and swapped in a new passenger side O2, swapped in a new coil pack, fuel filter, checked all vacuum lines and PCV, cleaned MAF and tried a brand new one, vacuum at manifold 18.5-19.5 in., fuel pressure good, seems to be getting poor gas mileage.
Spark plugs seemed dirty to me, here is a picture: http://picasaweb.google.com/jeffceo24/Truck/photo#5116765817055358610
Please help, I am making a donation!
Thank You
SPONSORED LINKS
Monday, December 31st, 2007 AT 1:07 PM
