1997 Ford F-150 4X4
STILLWATER10
  • 1997 FORD F-150
  • V8
  • 4WD
  • 21,000 MILES
Is there any way to manually switch out of four wheel low from the transfer case on a automatic trans ( ESOF). Placed a new TC motor on it would not turn. No clicking when I turn the switch. ( Placed in neutral brake pressed down turn switch, nothing, no click or clunk )
Thursday, January 8th, 2009 AT 5:57 PM
RACEFAN966
  • 5,029 POSTS
Ok the GEM module needs to be checked it is mounted on the fuse block. I also need you check the front actuator for proper hook up. Here is a vacuum diagram of it so you can make sure all it hooked up correctly. Now I need to know if you have a test light and a digital multi meter to test the GEM with. Get back to me. Don't forget to check the 4x4 fuse too.
https://www.2carpros.com/forum/automotive_pictures/249564_Graphic_12.jpg
Monday, April 12th, 2021 AT 11:17 AM
STILLWATER10
  • 27 POSTS
I have a test light and multi meter the fuse is good.
RACEFAN966
  • 5,029 POSTS
Good now please check all the vacuum lines and make sure everything is routed properly and that there is no vacuum leaks anywhere. Let me know what you find and we will go to the next step.
STILLWATER10
  • 27 POSTS
I warmed up my truck this morning and just for the hell of it put it in nutral pressed on the brake pedal and switched it in four low both lights came on, I then switched it in four high it clicked, then moved it to two wheel it clicked. Drove great. WTF
STILLWATER10
  • 27 POSTS
Before I started my truck I did check on some wiring harness that I belive are connected to the actuator.
RACEFAN966
  • 5,029 POSTS
Well if it is working then we can't find the problem as the problem is not there now. You may have found a loose connection when you where checking the wiring. If there is any more problems let me know and we will work on it.
STILLWATER10
  • 27 POSTS
Hank you for your help.
RACEFAN966
  • 5,029 POSTS
No problem if you have any other problems get in touch with me and we see what we can find. Thanks again.
