1997 Ford F-150
RHILL7499
  • 1997 FORD F-150
  • 6 CYL
  • MANUAL
  • 122,000 MILES
The hot engine gauge on my truck rises to the red. Hot mark when I drive 45 mph and more. I have checked the reservoir and have to put water in it each day. I am not truck mechanical at all. Any suggestions?
thanks,
Ronny
Wednesday, April 14th, 2010 AT 2:27 PM
CJ MEDEVAC
  • 11,005 POSTS
See my profile. I can give some suggestions:
Make sure your belt is on your water pump (not missing)
Your fan or fan clutch is bad
Your thermostat may be bad
Your lower radiator may be "squishy" (old) and the water pump is sucking it flat, restricting radiator "cooler" water into engine.
Radiator has internal buildup. Radiator shop clean/ replace
Can't leave this one out!---Whatever you have in front of the grill---is blocking airflow.
100,000,000 insects are imbedded in the radiator fins!
Go to Advance Auto or Autozone for FREE ASSISTACE. May can direct you to a "REASONABLE and REPUTABLE" radiator/ mechanic SHOP!
Keep me informed!
Love, Turddog
Wednesday, April 14th, 2010 AT 10:50 PM
